Possible glitch??
4290.10 In reply to 4290.9
Hi Felix,
> Would it be possible to have an interface something like for
> extrude and possibly even better one "set dir" for each curve
> for the worst case scenario where each curve is a line and the
> "extrude dir is not perpendicular!
You can actually just do an extrude if you want - extrude each curve out to a surface and then select the 2 surfaces and run the Isect command. That way you will be able to get the full Extrude interface because you'll really be using Extrude.
This command is meant to be a kind of a shortcut for the more simple situation where all that other interface stuff is not necessary...
> I'd like your advice also for other "potential glitch" if ever
> one come by again, do you which we report then to you, to
> the forum or by pm.
The forum is usually best, because then other people have a chance to find about about what a possible solution might be. If you have a file that you want to keep private then instead of posting on the forum you can e-mail it to me at moi@moi3d.com.
