Image command
4274.2 In reply to 4274.1
Hi Burr, yes that's actually set up automatically.... For example if you drag or size an image you can undo that while you are still within that command.
You don't need to do anything special to activate that, just hit the regular Undo button on the bottom toolbar to undo your last image change.
When you exit the Image command then Undo will be back to its regular function of undoing geometry changes.
