Hi Jeff, also, you wrote:
> I'm getting back to my learning project
This is actually a quite complex project that you're tackling here... It's maybe a bit like learning how to drive by jumping on the Indy 500 racetrack right away.
It can actually be particularly difficult task just in general to try and reverse engineer the structure of an object when all you have are some parts outlined at awkward angles.
That's a lot different kind of a project than one where you're more freely creating an object just according to your own desires, because you are then more free to create surfaces using simple cross sections that can then be rotated into place instead of trying to figure out how to match some projected already rotated profile.
So that's something to keep in mind, that this is just generally a difficult area that you've chewed off here.
