I'm getting back to my learning project, a stratocaster guitar model, and having problems again.
Here are some of the basic curves....
The line at an angle that cuts across the bottom right corner is the start a of a sloped section that thins out to the edge with a graceful slope.
The blueprint I'm working from provides this starting point, a right cross section with the profile of the slope & the position of the cross section in the top view.
My idea to create this is:
1. offset lines from the start of the slope
2. move them down to match the slope of the cross section, loft a surface and then use it to trim the body "slab"
    The main problem is that I need move the lines to match the profile at the intersection of the lines and the plane that defines the cross section. I tried drawing a plane at the cross section, but don't know how to "mark" the lines at that point to move them in place to match the profile on the blueprint.
My next issue seems to be a common problem that people have - filleting. I think someone needs to write a filleting strategy and tutorial to cover all the limitations and strategies to overcome them. I think I understand some of the reasons for the problems, but don't know how to resolve them.
The overall shape is in the first image. The blueprint calls for a 7/16" roundover on the edges except at the bottom of the neck pocket area (highlighted below) where is specifies 1/8".
Here are some of the issues and strange behaviors..
1. 7/16" doesn't work, but I did get 0.3 to work on the top profile after I cut out the neck pocket, but now it doesn't work.
2. After cutting out the neck pocket and highlighting the leftover top edge sometimes I got a long fillet like projection shooting off into space when I ran the command.
3. On the bottom I want the larger fillet ending around the "horn" to start blending into the 1/8" fillet at the neck pocket area. How do I do this? I looked at my strat body and it is made this way.
4. Can I just fillet section of the top edges at a time? If so how do I do this?
Probably lots more issues/questions....
I want to let you know that I think MOI is a great piece of software and the forum is also great! I feel like I'm getting personal 3D modeling instruction.
I'll post my model (may have hidden elements) if it helps to understand what I'm going through.
Thanks for the help.
Jeff
BTW, I'm using a freeware program called "picpick" to do the screen clips and annoted them. It seems to work well for me. I'm running XP so I don't have built in tools.
