Hi Jeff, here is a solution for you for now.
Download the attached 2 files and copy them into your MoI installation folder.
Then instead of running MoI.exe directly, you instead want to start things up by running the Launch.cmd file.
That will run a small script that throws away the saved position from the moi.ini file, and then starts up MoI.exe. Since MoI will not then see any saved position information it will start up in a default location and should avoid needing to do any of that monitor shuffling that you were describing.
Please let me know if this does not work for you.
