trim/boolean/extrude command with curves
4228.6 In reply to 4228.5
< but I'm not sure why that would be useful?
say you draw a hull
you draw some stations in top view without special spacing
launch the automatic sweep
So the stations are equally positionned
then you can move or transform each station profil in the result if needing ;)
And re-use them in a normal sweep
(move horizontally a profil between 2 others are no effect in the automatic sweep mode)
EDITED: 28 Apr 2011 by PILOU
