> In this mode profils generator equally generated are not
> visible in the result
> Is that normal?
The profiles are what define the shape of the result, so they are visible in the sense that you can see the resulting sweep surface that was created using the profile...
It is normal that there are not extra curve objects created in the result - that's because the sweep command is focused on building surfaces, not on creating curves.
I suppose it could have been possible to temporarily draw the positioned curves and have those go away when the command ended, but I'm not sure why that would be useful? It can actually be nice when you don't have too much stuff drawing on top of each other when it is not needed.
