How to do it?
4227.8 In reply to 4227.7
> an easy way is duplicate the curve make some deformations
> without add segments then make the loft
Yup, that will make the result have the loft created with each segment matching the corresponding segment in the deformed curve.
Basically when there is the same number of segments between 2 curves, then the loft is the equivalent of doing the loft between each pair of segments separately and having the results joined together.
