strange start-up
4225.2 In reply to 4225.1
Hi Mark, did you recently install Internet Explorer version 9 on your system?
What you are describing sounds like a glitch that was introduced in IE9 which affects MoI in that way on some systems.
What happens if you maximize the MoI window so that it takes up the whole screen, does the problem on startup go away after that?
I do plan on making an update patch to solve this startup display problem with IE9 installed, I haven't quite figured out what is going on yet though because it does not happen on every system.
> This is not a huge problem, but it doesn't seem right,
> and I worry that something else might be wrong.
As far as I know the only thing that is wrong with MoI running on IE9 is that cosmetic startup glitch.
If you want, you can uninstall IE9 and go back to IE8 which will solve the problem for now.
