fixing a solid
4197.3 In reply to 4197.1
Hi Jim, so you will want to delete the faces as the first step - that will then leave a hole there and then to repair the hole you'll need to separate out the surrounding surfaces so that they are just totally individual surfaces not joined to anything else, then select some boundaries and push Delete to untrim them, then retrim the surfaces.
I'll see if I can get it most of the way there for you.
