IGS to LWO with MOI
4193.2 In reply to 4193.1
Hi Wedgie, the way I do it from IGES to Modo is more or less the same as you. Saving as LWO, Weld vertices ticked, angel 6. divide larger than 5. In Modo I delete all in "Other Maps" put all layers in one and move the pivot to where I like to have it. Only dubblesided material and with a Smoothing Angle to 10 degrees. Then there is no problem to animate it.
Good Luck
Chestnut
