Middle curves
4180.4 In reply to 4180.1
Hi ed, no there's nothing really like that right now for doing "in between" curves.
But what you show there looks a lot like a projected image of a kind of rotated set of curves, so you could possibly make it by making the full 3D curves first and then squishing them.
That would be something like - start with one curve like this:
Go to a side view and use Transform > Array > Circular to replicate it in a radial pattern:
Delete the bottom half:
Select those curves, and then go to a side view to squish them flat - do that by grabbing the corner edit frame grip here (you may want to click on the grip once before dragging it to switch from "scale from center" mode to "scale from opposite corner" mode):
Then drag it downwards until you get the "flat" snap like this:
That will make this kind of a result:
