Sketch UP import improvement
4170.1
I have been trying to use the SKetchup export. The geometries seem to be very clean, however there are a few improvements which would be very important:
- all object that share edges are welded together in sketch up, even if they were separate objects in Moi.
- materials and layers are not translated.
I am not sure how much you could add to the export functionality, but ideally, every object should be saved a 'group' in sketchup,
so that sketchup understands the different objects as such (and does not try to weld the overlapping edges).
- Object names or styles should translate to Layers in sketchup.
Otherwise, names should translate to layers, and Styles to materials.
If this could be added, it would hugely improve the functionality of the export.
Thanks!
