Parametrics
417.5 In reply to 417.4
Question on History:
How do you know if the history is enabled or disabled on an object?
I am still adjusting to the GUI and am not sure if i am just missing something obvious. Is there somewhere that lists object properties? Maybe that shows the current state of the object being selected?
When I run history, all I see is a prompt for select objects, if i have not already, then enable or disable.
Just curious, if more indepth parametrics were in effect, would there be a much larger draw on system resources?
How do you get any work down with all the effort you put into your forum?
Thanks for making me budget a new tabletPC. By the way, are there any you would recommend?
