trim too
4129.5 In reply to 4129.1
Hi Rich, also one additional note on Trim as it works currently - when you go to pick the pieces to discard or keep (depending on what the Mode option is set to in the Trim command), you can use window selection at that point as well as single click type selection.
Window selection can help in a lot of situations, like for instance here wanting to trim off the ends of all these lines:
When you run the Trim command and select the horizontal line as the cutting object, instead of clicking on all the little individual fragments you can do a window select to grab them all in one step like this:
