> The funny thing of your Boolean treatment is we can put any
> lines around the object and make the boolean diff in the same
> time! (lines here erased)
Yup, you can use any number of cuts at the same time.
> So something cool will be a function "explode" from a central point for
> automaticaly separate the objects created :)
This and the sort of "slide like array dir" are definitely cool ideas!
But I think it will be a while before I will be able to work on them though, there are some other more basic things I should fix up before that.
> Ps Object can't be move also by arrows key?
Not yet... But that is another good feature that will come sooner or later. I'm not sure if this one will get into V1 or not yet.
