> Is that work for curve lines too on a same plan?
Yes - all of these curves were on the same plane.
> And for lines not in the same plan? (but with commun points)
Nope, this will only work for curves that are all on one common plane.
> You have moved or erase something?
Yes sorry I forgot to mention - I moved a couple of pieces to illustrate that the results are all closed loops, not just separate line segments.
