Hi Pilou, I tried to do Patch, but the one currently in the geometry library that I'm using did not work very well. I was originally going to have a "Patch" item under construct, with Network, Coons, and N-Sided patch under there.
However, Patch wasn't working well, and then I figured out how to combine Network and Coons into one single command.
Hopefully with a geometry library update I will be able to do an ok Patch command for V2.
