| Hi Rudy - the commands folder is located on your computer at:C:\Program Files\MoI beta Mar-29-2007\commands
 To add the keyboard shortcut, you will need to open the moi.ini file in notepad. To do this, first make sure that MoI is closed, then go to Start / Run and type in "notepad".
 From Notepad, do File/Open and open this file:
 C:\Documents and Settings\Michael\Application Data\Moi\moi.ini
 This file is where MoI saves all of your options settings, it also lists all the keyboard shortcuts. Right now to activate a custom command you have to set up a keyboard shortcut. Make sure you close MoI before editing this file.
 Scroll down until you find the section [Shortcut Keys], and add a line directly underneath it:
 [Shortcut Keys]
 Alt+D=CustomDistance
 Then save the file. Now the next time when you run MoI, you can use Alt + D to activate Petr's "CustomDistance" command.
 Let me know if you get stuck on any of these steps.
 I am planning on making an easier way to run custom commands, I just haven't got to it yet...
