| Done some more testing.
 With the LightWave Normal export, when I bring the LWO into LightWave the entire Vertex Normal map needs flipping on all axis to look and render correctly.
 With the modo Normal export, when I bring the LWO into LightWave the Z axis on the Vertex Normal map needs flipping to look and render correctly.
 So, as it stands, none of the options import pefectly without some extra work in LightWave.
 Matt
