Hi there I been having some problem or maybe I dont quite understand the sweep tool properly
How many profiles can you use with 1 rail and how many with 2 rails
for 1 rail i can use 2 profile but there a tad iffy
for two rails I cant use more then 1 profile as nothing is generated
also when using 2 rail and a profile if I have corner points that breaks up the final result as per the corners on say a rail
is that normal? ie no corner points aloud ?
