Hi Jamie,
> Although remaining editable after making a solid would
> be great I can see the trade off with complexity.
One of the tricky parts about that is that the surrounding faces may not have underlying surfaces that extend far enough to fill stuff in, in which case they need to be extended and doing that well is a difficult business.
> In fact any chance of a script to explode and untrim all?
Yup, try the attached UntrimAll plugin. To install it, unzip it and copy the 2 files into the \commands sub-folder that is underneath MoI 2.0's main installation folder.
That will then make a new command named UntrimAll available - to trigger it make a new shortcut key and put in UntrimAll as the command name.
That should then give you a combined explode and untrim of all exploded faces in one keystroke.
