eps export
4065.2 In reply to 4065.1
Hi Paul - MoI does not have an eps export. But it can export 2D curves to .ai format though, and most of the time programs that would read .eps files should usually read .ai files as well.
The .ai format (for Adobe Illustrator v8 and lower which is the type that MoI writes) is actually very similar to .eps and it may be possible for you to just rename the .ai file that MoI writes to have an .eps file extension and see if that might work.
What application are you trying to read the eps file into?
