Hi Armin, also with the method above - when you launch a program from a Windows shortcut icon, one of the properties for the shortcut is a setting called "Start in:" - that sets what the current directory is for the program when it is launched.
If you're starting MoI from a shortcut you'll probably want to leave that "Start in" setting in the shortcut itself to be blank which should probably make the folder that the program is in to be its current directory.
