Understanding the Network command
4014.4 In reply to 4014.1
The curves you use the generate surfaces and solids in MoI, remain... Just after you create and object like this, they will actually remain "selected".. You can either rename/stylize them to hide and keep, or delete right away..
Actually, MoI has a history mechanism.. Just after you generate your network, turn on control points for one of those generating curves, and adjust it a bit... You'll see the command calculation begin again, and the surface/solid will update!!!
FYI
