question on blending curves/edges
3984.1
I was trying to follow along this tutorial:
http://www.rhino3dhelp.com/tutorials/learn-how-to-model-a-bottle/
But ran into some hiccups when trying to blend between the edges in page2/step3 of the tutorial. Is there a set of rules that Moi uses to determine if 2 edges can be blended? At first I thought that the issue was the two curves didn't have the same number of points, so I tried created 2 curves, one as the tutorial shows with overlapping circles, and filleted corners, then a second curve made by an ellipse. Then I ran the rebuild command, using the points option to give both curves 20 points. If I select both and try and run the blend command, no dice, nothing seems to work. Any advice? Is there a different workflow I should be using with moi, vs Rhino?
Cheers!
//edit
Doh! OK at least part of the problem in my experiment was that I was only using 2 curves. I presume that the objects being joined need to actually be surfaces first, or at least one does. So maybe all that's left is making sure that the curve points are equivalent?
EDITED: 17 Jan 2011 by JIMCRAFTON
