newby - weird radii - how to create for cnc cutting
3970.3 In reply to 3970.1
Hi Gary, then some other problems are that some of the pieces that look like they should be tangent are actually a bit off.
Do you have your original curves that you used to create this object? If I could check those out that may help me to give you some tips.
For example this area here:
That is not smooth at that juncture there - the curved arc piece on the right-hand side does not come to a full flat tangent, it has an ending tangent that looks like this:
That kind of thing where you've got 2 pieces that are are not smooth but coming within 5 degrees or so of being smoother are difficult for filleting to handle. It's a lot better for such things to be more accurate to be tangent where they meet. Anyway, that's probably what is causing some fillet problems in that particular area.
