3D Poser man inside MOI ??? A solution Michael, please.
3969.4 In reply to 3969.1
Hi Pierre, most likely the Quidam 3DM export was only creating polygon mesh objects in their exported 3DM files.
3DM files can contain a lot of different kinds of things, like NURBS solids, NURBS curves, dimension annotations, spotlights, polygon mesh objects, etc... But MoI only reads and writes NURBS objects from 3DM files.
> How is it possible to import 3d people in MOI to design
> with 3d human references
You can convert a polygon mesh object in OBJ format into a set of wireframe lines that can then be opened in MoI using the utility here:
http://moi3d.com/wiki/Resources#Obj23dmWireframe_converter
So to use that export from Quidam or Poser as an OBJ file, then run that utility to load the OBJ file and write out a 3DM file - that 3DM file will contain curves in it with one line for each edge in the polygon model data. That 3DM file can then be imported into MoI to get a wireframe of the mesh data.
