| Hi Burr,
 > Although called "sweep", it seems to be more "Rail Revolve"
 > that the input curve is drawn while in the command.
 What if you want to use some curve you have already previously drawn instead of drawing a new one, is there any way for it to do that, or does this particular command in Amapi actually _only_ work with points that you then pick after launching it?
 > So , pick the rail (the circle to start with) then the command
 > is waiting for the pick points. the revolve surface is drawn in
 > with each pick.. No 25 curve commands... Just utilizing curve
 > through points as a method.
 So it's only fixed to use just that one particular "through points" method and not any other kind of curve drawing method? What if you want to make some lines and tangent arcs in there or something like that, are you just out of luck?
