Fillet help please
3956.2 In reply to 3956.1
Hi Alexander,
Instead of using the edge to apply the blend use surface to surface blend, to do this separate your model into individual surfaces [Edit] > [Separate] pick the two surfaces then apply the blend, I managed to get up to 2.85mm rad, when satisfied join the surfaces back up again [Edit] > [Join] and the shell command will work.
Find the result attached.
