no fillet
3949.2 In reply to 3949.1
Hello Fil,
If you scale the model and then select the entire model for fillet, it will succeed.
Open model and select and run scale. Type 0 and hit enter, then type .1 to scale it down by 10.. Then select the entire solid and run fillet with a value of .2 rescale back by 10.
Note that the fillet actually does these areas here too. I think this is the area that is giving the fillet issues with other methods...
I've attached your model here with the fillet from the above method.
