New Feb-9-2007 beta available now
A new Feb-9-2007 beta release is now available from the download page at http://moi3d.com/download.htm .
New stuff:
Updated background images - you can now move or scale background images. To do this, click and drag on either the image or the corner scaling grip while inside of the View/Image command.
Undo for selection - if you make a selection mistake you can now hit undo to recover the previous selection.
Undo now works to remove the last picked point in the curve and polyline tools.
New polygon star command.
New elliptical option for arc center.
New setting in mesh dialog that allows "Divide larger than" to also apply to planar faces.
New point order options for arc through 3 points.
A right-click on a viewport's "Reset" button will now do a reset all.
New red rectangle warning indicator when you have curve control points stacked up (stacked up points tends to cause various problems with intersections and some other stuff).
Updated crash handling - the crash dialog now has a button you can use to save your model data in the event of a program crash.
Added cap ends option to revolve and rail revolve.
Tuned Direct3D display engine to reduce peak video memory usage, this solves some problems on devices with lower amounts of video memory.
Made opening a file by double-clicking a .3dm file in Windows Explorer work, once you have set MoI.exe as the program to handle .3dm files.
Updated revolve so that cases where you pick the revolve axis down the center of a curve will work, it now automatically trims the revolve profile by the axis if the curve crosses the axis.
Added a new option in moi.ini to keep OBJ export with z-up coordinate system:
[OBJ Export]
SwapAxes=n
Plus quite a bunch of other bug fixes...
