MoI Trial won't work...
3909.2 In reply to 3909.1
Hi d3signr, the 30-day trial version has a kind of anti-hacking security wrapper around it, and apparently some kind of component on your system (like an anti-virus or anti-spyware system or something along those lines) doesn't get along with it.
You could try temporarily disabling any of those systems that you may be running that hook into the operating system at a low level and see if the trial version will run ok when they are disabled.
Other than that, you can try the alternate trial version at the bottom of the page here:
http://moi3d.com/download.htm
That version does not have the anti-hacking wrapper (and so should likely run on your system even with whatever you've got running still in place) and also does not expire, instead it has saving disabled.
