controlling sweep positions
3893.3 In reply to 3893.2
> o use manual place mode with multiple profiles you'll generally want the rail to be nearby the profiles and not have the profiles offset far > > to one side
I placed it in the middle of the plane profile which has to follow the rail exactly. The surrounding profiles just have to follow the plane profile. So in z-axis I can't move cause it would deform the sweept plane-profile. Moving in X and Y-axis moves the profiles in there location.
> auto place mode will only kick in if you have the profiles all on the same plane
I tried this with the lower profile moving x-backward but it seams not to work
Is there a way to force the manual-place mode or even make it default? I addached the moi-file for better understanding.
~ nos
