bending objects
3875.18 In reply to 3875.17
Hi nos,
> So could you please explane what determinates the size
> and the position of the aligned object (beside the trimming).
It just maps from the base surface to the target surface, but as I mentioned above it uses the underlying surfaces for this mapping, so look at the full untrimmed surface (one way to see it is by turning on control points) to see what will actually be used for the mapping.
> But now it's to big.
So that means that you want to increase the size of the base surface plane - scale it up or something so that the object you are deforming is contained inside of it with some space around it rather than having them right snug up against each other.
The same relationship of the object being morphed in relation to the base surface will then be applied to the target surface. That includes spacing, so increase the spacing around the base surface to then apply that same spacing to the target surface.
