| Hi Andy,
 > I have taken the same approach with nurbs. Start
 > with the basic shape, trim the cuts, and then I used
 > shell to add thickness to them and fillet the connecting
 > edges. This gives me the look that I am after but I am
 > not sure if it is the proper, or best way of approaching
 > this problem.
 So just to clarify - there is nothing wrong about that technique of using Trim + Shell + fillet.
 But it can be somewhat more convenient in general to stay working with all solids when possible, it can end up saving some steps. Working with individual surfaces is a somewhat more "low level" kind of an approach.
 So for example in your model there instead of doing Trim + Shell to generate the multiple pieces instead you could keep things in solids by using boolean difference on the solid to generate the multiple pieces.
