Paneling Techniques.
3859.1
I think I am getting a pretty good grasp of nurbs modeling. One question I have though is on the proper technique for creating panel lines. Say the spaces between the hull plates on an aircraft wing.
With subpatch modeling I would bevel in the edges of the shape, add a controlling edge to tighten up the edge and then subpatch it, this gives me nice lines between the different plates when it is subpatched.
I have taken the same approach with nurbs. Start with the basic shape, trim the cuts, and then I used shell to add thickness to them and fillet the connecting edges. This gives me the look that I am after but I am not sure if it is the proper, or best way of approaching this problem. The only other solution that I could think of was to sweep a circle along the panel lines and boolean them out. That seemed like it would create more problems to me, but that might be the anti-boolean mentality that comes from years of subpatch modeling.
EDITED: 15 Nov 2010 by ANDYJAGGY
Size: 144 KB, Downloaded: 53 times, Dimensions: 714x732px
