Oblique view (Plan oblique 45 degrees)
3845.4 In reply to 3845.3
Pretty sure this works... Here, I just used extrude on my curves in the plan view, and "set dir" for the angle desired... I DID do some work to color lines to get the hidden lines effect...
I also fooled around with setting a CPlane at the angle I wanted, then used the edit frame to hit the "flat" option in one of the ortho views to "freeze" the 3d model..
