relative & absolute angles
3840.4 In reply to 3840.3
Hi nos, the rotate command will always display its numeric feedback as you move the mouse around as a 0 to 360 angle in the counter-clockwise direction, which is the most common way that CAD programs behave. But like you mentioned you can still type in negative inputs to give angles in the clockwise direction instead.
There isn't any checkbox-like option to change the display, but the numeric feedback is done through a script function so it is possible to modify the UI to use +/- angles if you want.
But I'm not sure if I understand what you want, you wrote "+/- counting from 0-359?" which I don't think is possible, do you mean having a range of 0 to +180 or 0 to -180 ?
Like for example would you want the angle that currently shows as 270 degrees to instead show as -90 ?
