Hi George,
> I think is better to have 2 points , since one will be used
> (the remaining point(s) does not complicate the plan).
> Probably a selection between them, about the side, will solve it.
I should be able to set something for that up.
Would a command that had a sequence like this work:
Pick point P1
Enter distance L1
Pick point P2
Enter distance L2
Pick point, intersection point closest to the picked point is taken.
Or would you want a different sequence, like pick both points first and then enter the distances?
