add elements to an object
3830.28 In reply to 3830.27
>It's just a label that you can assign as you wish to help you tag things.
And more than a single label assigned to a object?
Example: an object (first label) can be a part of a bigger structure (second label) inside a project (third label) = finger_hand_body.
In this way I can select the object trough 3 different tags...in order to select it on its own or with other objects.
FiL
___________________
That's a brilliant day!
