>I've attached here a different version which will read in the list of names from a text file named PresetNames.txt which should be put in the same \commands sub-folder.
1-I've inserted the command "AssignPresetName" inside the commands folder.
2-I've changed your generic list in a personal list.
3-I've assigned the short key to the new command.
But it doesn't work. It doesn't found names in PresetNames.txt file
Is there an error in what I did?
Did I put the .txt file in a errate place?
FiL
___________________
That's a brilliant day! |
