shortcut assignments
3808.24 In reply to 3808.22
Hi krass,
> 1 - where can I find a list of all the hotkeys (scripts) for my3d tools?
There are some of the most commonly used scripts listed here:
https://moi3d.com/4.0/docs/moi_command_reference11.htm#shortcutkeys
like Hide, Lock, reset all views, select all, deselect all, invert selection, go to split view, maximize 3d/top/front/right view, isolate selection, select all curves, turn grid snap on/off, and some more.
Also there are more scripts here:
https://moi3d.com/download/scripts/PetrsMoiPage/PetrsMoiPage.htm
> 2 - is it possible to bind the rotation of the selected object to the scroll/dial
> wheels (now it is done by holding the mouse and rotating it)?
Sorry no, the mouse scroll wheel is used in MOI for zooming the view in and out. There isn't any way to set it to do object rotation instead of that.
It is possible to set up a shortcut key that would rotate the selected objects by one step though, would you like that? Scripts that modify objects are set up a little differently than ones that modify settings.
