How to fillet this extruded object
3799.3 In reply to 3799.1
Hi Leonard, there were some issues with the edges you showed in the pic as well as the ones crossing the seam of the top and bottom surfaces. I merged the edges and rebuilt them with the Rebuild command, then deleted the side surfaces and swept them back using the reconstructed edges.
When you need to project curves onto a surface like that it's always best drawing a sphere and cut it with a line, just as Pilou shows in his msg. This way you can leave out the seam, that often causes problems with fillet and offset.
Hope this helps,
cheers
Dan
"The darker the night, the closer the dawn."
(Buddhist Proverb)
