mesh export and normal
3781.5 In reply to 3781.4
Hi PP,
Yes, the problem you are seeing will be the normals, but the normals in MoI are generated from the direction of the curves that are creating the surfaces. So your construction lines made in xara are what are actually causing the "problem"
Adding thickness is probably the best/easiest way to stop this problem.
- Steve
