Colored Style lines
3766.7 In reply to 3766.5
Here's another example that MoI's construction lines can do because they have a start and end point (and thus have a distance associated with them), unlike inference lines that only radiate rays out from a single point.
When you define a cline between these 2 points:
Not only is the midpoint between them available as a snap (or any division like thirds or fifths, etc... if you pop up the menu and activate that), there are also snaps available at that same distance reflected over, like this:
That enables you to do things like make a construction line perpendicular to a center line and then get the point on the opposite site, here's an example, note that when dropping the cline to the center line, the mirrored point on the opposite side is then available:
