Hi Burr, yeah maybe in v3 one possibility would be to make it put in 2 crossing construction lines so that then you could snap on to the points you wanted on those to make the lines.
But also right now instead of using trimming you can just draw in a second line using the first one to snap on to (with construction lines also) which may be a bit easier than using Trim.
