Fillet - No Use 2 Distances Option :(
3713.4
Steve - good idea, thanks :)
Michael - Yes, I was thinking that because the fillet tool supported non-circular shapes (you currently have Circular, Const Dist, G1 Blend, G2 Blend, G3 Blend) I figured that you were already able to do non-circular fillets?
I have attached a model with the loop selection problem (I was using 2 curves to try to select the loop, but no luck).
Try selecting the loop like I had in that first pic above - I have to do it manually.
> the filleting engine does not like to entirely consume and eliminate faces like this.
Is this a possible feature for the future? I find that I do a lot of this :)
Thanks as always Michael!!
