Hi Michael
Just found a little problem where the construction lines don't seem to be working correctly when using the Scale tool.
eg. Create a line
Select the Scale 1D tool
Select the Start and End points for the scale
Now you cannot create construction lines, except for on the locked axis that you have created.
(perhaps has something to do with the fact that the little crosshair indicator is locked to the selected axis?)
