sweep reversed
3687.1
Hello,
I am following the pod tutorial and I am making a leg. When I draw a few curves (circles of different shapes) and then try to sweep them along the rail the order is reversed.
For instance, I draw a large circle and then to the right of this I draw a small circle. I have a freeform line drawn above these two circles (for the rail).
I select both circles, transform, sweep, select the rail, click done.
Now the 'leg' I have just created (pod tutorial) is larger on the right side - the order is reversed. It should be larger on the left side.
Anyone know what I am doing wrong? Thanks
Size: 117.5 KB, Downloaded: 60 times, Dimensions: 1030x1012px
